Took some parts to a local machinest to make on a lathe for me. This is the first time I have had someone else help me and I am not happy about it, Wish I could afford a lathe right now. Finished up the flap hinges except cutting the sleeve to length. Started on the aileron hinges which are a bit more complicated. Made all the washers from the .080 material using a hole saw, I cut the .063 caps and .072 caps with a band saw and used a grinder to get them somewhat round. They do not have to be perfectly round since you are going to weld them on and you can just melt the extra material into the bead. I just ground the parts down on a grinder after welding them up. They look great cause you can not even find the weld lines. Started making the mounts but discovered I am in need of longer bolts to hold it all in place. Time to order more material.
