Had to remake all my attach angles for the rear spar. Got them recreated and primed on the side that goes to the spar. Also got them installed onto the spar until I got to the second spar on the 7th rib connection and I mounted it in the 8th rib slot. I was making mistake after mistake on the 2nd spar and was spending more time fixing mistakes than working on good progress. I decided to call it a day since I had been at it for most of the day after church. Good day though. I am really close to finishing up my spars now. Probably just a couple more hours and I will be ready to remove the 2x4's off the table.
