I began attaching the attach angles to the spar. They are predrilled for the rib side and one hole on the spar side that is 1/2 from the top of the angle. I clecoed this #5 rivet location and then flipped the spar to site the centerline thru the other #5 rivet hole. Once centered I then clamped in place and match drilled through the spar into the attach angle. Then I remove and debur and re cleco in place the angle at the two #5 rivet holes. Placed the #4 rivets and rivetted them in place. I will go back and do all the #5 rivets at one time as to not have to change the rivet set constantly. Ran into a couple items that I need to research. at the number 9 rib location I am unsure how the attach angle mounts as this location gets the steel flap drive mechanism on the back. Not sure if that bolts in place and holds the angle or if I need to rivet the angle. Also at rib location 12 my angle is going to be to close to the strut attach fittings. I may be able to just reverse the rib flange and fix the problem but I need to review the plans and make sure that will not cause a problem.
