Was able to finish up some details on rear spar number 1. Splice plate is in, wing attach fittings are all done and drilled. Still need some #30 clecos so I can drill the web spacers on out but that is about all. Still need to make attach angles for both the rear and main spars. I was able to get rear spar number 2 laid out and clamped today. I also marked and pilot drilled the lightening hole locations for this spar.
