Got some more clecos in and was able to finish drilling the spar/rib spacers on the main spar. This only took about 30 minutes. After that I spent some time organizing the shop and cleaning before starting on the rear spars. Started on the right rear spar and made it to the point where the aft capstrip is drilled for rivet holes with just the pilot hole number 40 drilled.
