Borrowed a pin extractor from Joe next door and was able to remove and reverse the fuel flow meter pins at the connector. Set up a fuel can to catch fuel and turned the pump on - voila! Gauge reads 42.3 g.p.h.. Finished the wiring on the canopy and inserted the pins in the canopy connector, everything works! Fans, canopy open switch, Red and White LED lighting. Woo hoo! Did some more grinding on the upper cowl. More to do but its looking right.
