Received star washers from Aircraft Spruce so installed and torqued nuts on fuel servo. Installed right side spark wire passthrough on baffle plate and routed right side lower spark wires. Set alternator belt tension (12 ft/lbs to slip, 3/8 in belt) and safety wired bolt. Reinstalled airbox.
