Worked more on canopy wiring, fans and canopy switch work, LED does not. Determined that the ELT cockpit remote had the label reversed - 'test' was actually 'on'. Not good. Was able to disassemble the unit and reverse the label. Cleaned up ELT wiring. Cleaned glue and foam residue off tail surfaces (remnant from the move south). Installed cover plates on step access and empennage fairing.
