Sanded more on the right elevator tip, scuffed surface of all three tips and then sprayed primer. Left tip needs more work. Cleaned shop, very messy from fiberglass work, lots of dust. Fixed up left tip and re-sprayed primer. Final drilled #30 and countersunk tips, dimpled metal and attached tip. Bent up the Empennage gap covers per plans.
