double flush riveted the trailing edge of the Left and Right elevators. Completed misc. remaining rivets on close-out tabs and root ribs. Bent and installed hinge pin for trim tab.Drilled 1/16" hole and safety wired hinge pin using .032 wire. Assembled and riveted servo to cover plate
