Brief Description: cowl finished, plane is complete!
Drilled holes for the right side lower cowl air inlet, countersunk then installed baffle and backing plate. installed lower and upper cown on plane and checked the fit, all looks good. Aside from a few things to do on the gear fairings after paint, this completes all of Vans instruction sets. N213GB is built!! On to the testing phase next. Also tried database updates again after talking with Garmin tech support. The GTN updated correctly but still no joy with the G3X Touch displays.
