Drilled, dimpled , and installed nutplates three places each side on lower wing root fairings. ProSealed the plastic spar shims in place. Balanced ailerons and set to 1/16" high each side. Checked right bellcrank for centering, need to do left. Centered control sticks and adjusted pushrods accordingly. Torqued and marked fasteners for aileron pushrods. Rolled plane outside to check GPS and Traffic, all works.
