Greg's RV-14A
Date:  9-19-2020
Number of Hours:  6.00
Brief Description:  last batch of parts prepped
Gathered final batch of part to be primed - wing attach skins and ribs, lower cowl closeout. Edge prepped parts, trial fit of skins showed that I had reversed the upper forward attach flanges many months ago. Drilled out 12 rivets, swapped left and right sides and re-riveted. Holes in wing attach skins line up correctly now. Cut flap pushrods to length and cleaned threads. Installed shoulder harness leads.
last of the loose parts
workshop overhead view
flanges drilled out
flanges drilled out
