Rechecked axle alignment and there is still a problem. Loosened and re-tightened left gear leg to get a better fit, still need to reduce toe-in by .5 degrees. Called Ted, he has cotter pins. Stopped to watch a Skycrane replace a TV tower antenna along the way to Teds house. Got cotter pins, came home and uncrated the engine! Started locating engine fittings.
