Cleared a bit off the right edge of center wire guides so that the circuit breaker panel will fit without interference. Mounted the circuit breaker panel then secured wiring so that it is secure yet easy to take down for inspections. Secured ground wire bundle and made up ground connections for all wires in bundle. Secured wire and made connector for canopy harness. Made ground wire for canopy connector and made two ground wires for the standby alternator voltage regulator.
