Greg's RV-14A
Date:  7-8-2020
Number of Hours:  5.00
Brief Description:  instrument panel
Drilled yet another set of holes for the GAD29. Removed the panel and harness and set it on the bench, took pictures and emailed them to SteinAir re: bad molex connector. Decided to mask plane and paint the interior some more, especially the canopy rails and sub-panel. It looks good! Drilled out the holes in the throttle drip down for the various sized cables. Talked with Josh at Stein and he is overnighting the necessary parts to fix the harness. Moved fuselage back on to the platform and removed the rotisserie.
harness
harness
reworking a connector
drilling to cable size
