Greg's RV-14A
Date:  5-8-2020
Number of Hours:  6.00
Brief Description:  nose wheel pant
Marked and drilled the starter holes at the nosewheel tow bar access hole. Got them both dead on! Marked wheel clearance and used the belt sander to get required clearance. Drilled tow bar holes in fairing. Disassembled wheel and drilled and tapped brackets 6-32. Prepped brackets for flox then mixed a batch and set it up. Trimmed the fainring that was already done.
