Spent more time routing fuselage wire harness and installing grommets. Repaired molex connector wire (orange) on passenger side stick connection. It had pulled loose while pulling the connectors through the passage holes. It took four tries to get a good on and connector back together. Made grounds for two sticks and lighter connections. Installed cigarette lighter and audio jacks. Filed the powdercoat at stick bases until connectors would snap in place.
