Greg's RV-14A
Date:  11-15-2017
Number of Hours:  6.50
Brief Description:  ailerons
Drilled and replaced a couple of rivets that I didn't like in the pushrods. Reset them using the gun instead of the squeezer and got a much better result. Fitted bearings to right and left aileron bellcranks and installed the bellcranks. Torqued bolts to 85 in/lbs and marked them with torque check. Manufactured left torque tube assembly and installed it in the left wing. Mis-drilled the right torque tube assembly, will have to order more tube for next year. Riveted ribs, leading edge and trailing edge to complete left aileron. Thats as far as I'll go this year, time to head to Florida for the winter.
torque tube bellcranks
torque tube installed
