Brief Description: right tank and leading edge parts prep
Pulled the right tank skin out of the rafters, scuffef the match lines on the interior. Drilled #19 holes to final size, drilled and dimpled attach bracket parts. Cleaned and primed external fuel tank parts except for Z brackets, prepped and primed right and left leading edge skins, separated Z brackets and stiffeners. Shaped, deburred and dimpled Z brackets and stiffeners.
