Greg's RV-14A
Date:  5-23-2017
Brief Description:  elevator clearance, drilled elevator horn
fussed with elevator leading edges, talked with Vans their opinion was that backing out bearing rod one full turn should be ok. Set bearing distance for both elevators and drilled upper elevator horn to HS center bearing hole.
HS and elevators
HS and elevators
elevator horn
elevator horn
