Installed static air lines , WH14 UAT antenna cable, WH15 ELT antenna cable, Tie wrapped things up and tidied up the wiring harness. Removed faceted edges from F1409 then re-primed part. Cleco'd aft deck and associated parts in place and did final drilling as called out on pg. 10-27. dimpled F1409 and F1414.
