Put away aft fuselage parts for now, skins are back in the attic. Drilled and dimpled trim tab skins, removed material to make fluch surface on two counterwieghts. Riveted spar and control arms to lower trim skin. Riveted ribs to right and left elevator skins. Riveted left elevator bottom skin to spar. Pop riveted rib halfs togeher on left elevator
