Greg's RV-14A
Date:  9-10-2016
Number of Hours:  3.50
Brief Description:  worked on Horizontal Stabilizer
Received parts from Aircraft Spruce and Cleaveland Tools. Riveted rudder horn brace with new longeron yoke, worked nice! H. Stab- drilled the riveted VA146 and 2 HS 911 together. Marked, cut and sanded to shape HS 913's and 914's. Attached and drilled hinge brackets, countersunk spar, drilled 4 #12 holes in spar
VA146 hinge parts
VA146 hinge parts
cleco'd
cleco'd
riveted
riveted
