Dimpled V. Stab skin, made 1 mistake but was able to hammer it smooth and redimple. Dimpled spars and ribs, countersunk some holes on 808PP doubler. Talked with Vans builder assist (Gus) about the poorly drilled hole I made on VS-01401. His advice was to carry on, and add a small doubler if the bolt is wobbly when its time to mount the v. stab. Riveted VS014001 to front spar (first rivets!!) looks nice. Got about half of the rivets into the rear spar assembly, but had trouble with the flush rivets. Drilled out more than I set. Will try again tomorrow.
