GARY'S WEB SITE
CH750
Elevator
11-16-2012
tip hinge and trim tab hinge
Located tip hinges and drilled 3/16" hole in tip rib. Back drilled #40 holes through rib into hinge. Located and drilled to #40 bent strips to ribs and spar. Drill and silver cleco hinge to trim tab.
determining front of spar
hinge clecoed 10mm from spar
CH750 Home
275
Elevator
Flaperons
Horizontal stabilize
Slats
