Brief Description: Leading Edge and Outboard Fairing Block
Before installing the urethane foam for the leading edge, a 1/2" OD vinyl tube was installed along the fron TLE. A hole was drilled thru R33 and R57. The tube was run to tjust in front of the Instrument Panel. In order to minimize the bump from the tube, a slot was cut from the BLE intersection with the fuselage up to the instrument panel.A string was pulled thru the tube to facilitate pulling wire in the future.
