After finishing the tables, they were used to set up the bottom skin foam. I cut it out with about 1" extra in all of the leading edge areas. The area where it contacts the center section spar is beveled so it was measured and cut accurately. All of the seams have been kept at least 6-8 inches from the leading edge so it will not be in the area that will be scribed and bent for the leading edge. The inboard foam was extended to the FS 50 location in preparation fo the BLE extension more commonly known as the Cozzy Girrl Strakes.
