I clamped the hinge brackets to the F28 equally spaced from the center and checked against the longerons. I clamped a board to the canopy hing brackets to keep them straight. I then drilled the holes and installed bolts. I placed the canopy back on and drilled the holes for the hinge brackets.The hinge did not sit flush with the bearing pad. Arggh!
