Michael's Cozy Web Site
Date:  6-23-2013
Manual Reference:  Step 5
Brief Description:  Installing the Windows
I started to remove the vertical support over the rear window to allow room to install the window. On the right window, the fiberglass pulled away from the foam while removing the bondo. I then repaired it by placing a thick micro and covering the gap with 2 plys BID.
