Brief Description: Landing Brake and Center Console
The center console was constructed similar to the plans. The main difference is that there is not any landing brake or landing light equipment to inclose. The throttle quadrant was integrated into the console. The fuel lines were routed from the fuel selector (positioned in front of the the throttle quadrant) around the throttle quadrant and back under the console. Nutserts were used in the heat duct to provide a fastening location for the console. The bottom of the console was set up so that it sits on a micro ledge. This will add extra support if the console is stepped on. A recess was added around the seat belt attachment to minimize interference with the set belt attachment.
