12/10/2008 I drilled the holes for the roll trim. To insert the long bolt, I had to drill a hole through the wheel well. I also cut out the bulkheads to direct the roll trim cable up. I 5 minute epoxied the tubing to the wood and then covered the tubing with 2 layer 01/09/2009 I cut the springs for the roll trim and bent up the connecting hoops.
