08/22/2008 I floxed in the acrylic glass on the pilot side of the wheel well. 08/23/2008 I prepped the fiberglass for epoxy and used flox to attach the wheel well. I overlayed the edge with a 2" wide BID tape and peel ply'd. I used a clamp made of long boards to squeexe the wheel well in the center to keep it aligned properly. 09/01/2008 I bought the molded nose section from FeatherLite so that I could install the landing light and taxi light in the nose cone. I used a plaster of paris mold that I made to drape melt the plexiglass. 09/05/2008 I floxed in the left light lens cover into the nose cone. 09/14/2008 I floxed the right lens cover into the nose cone. 09/20/2008 I trimmed out some foam on the horizontal nose cone bulkhead to allow the lights to be connected in a recessed hole for clearance. I also cut out an access hole. I covered the foam and the edges with fiberglass. 11/30/2008 I attached the NG31 and NG32 to FS0 bulkhead. I taped the joints with 2 plys BID
