The previous layer was sanded down and profiled as best as possible. There are still some low spots that need filling. The speed brake paddle was prepped for filler. All of the screws were removed. The speed brake was allowed to reach a natural location in the recess. The speed brake was covered and then lifted a few inches to seperate from the fuselage. Later after it was cured some, it was lifted to the vertical position. The rest of the bottom had several low spots filled in.About 260 g of resin was used in this step.
