The inside surface of the winglet and the top of the wing was filled with micro except for the area of the repair that was made when the bondo was removed. This area still had a layer of BID that was curing with a peel ply on it. Later in the evening, the repair had cured sufficiently to remove the peel ply and micro that area as well.
