The previous layer was sanded and profiled. The corners were profiled. There are still a few pockets that need to be filled. The amount that was sanded off is estimated to be between 200 and 300 g of cured micro.
The nose section was prepped and covered with micro paste.The profiled sections were covered lightly to fill in the pocket holes. 120g of resin were used to wet the entire bottom. 600 g resin was used to make the micro paste.
