Brief Description: Attachment, Wing to Center Section Spar
I epoxied the bushings into the holes and bolted the wing together. I also repaired the cut in the right outboard spar attachment reinforcement. Two layers of glass were cut through when I removed the bondo. I layed up two more layers from the top to the bottom.
