Brief Description: Attachment, Wing to Center Section Spar
I drilled out the wing attach bolt holes. First completing the 1/8" pilot then following them with the 5/8" counterbore. I stopped every few minutes and used water to help cool it down. It took over an hour per hole. After all of the holes were finished, the leveling boards were bondo'd to the wing and the center spar.
