Brief Description: Assembly of Foam Cores - Right Wing
I set up the jigs, leveled them with the water level and aligned them with the laser. I trial fit the cores. I found that FC1 had an error in the angle of the cut. It was off about 4-5 ° which left about a 1 " gap at the trailing edge.
