I inserted the Audio Panel to test it out. It powered up normally. I attached my headset and listened for Dynon warnings. They came through very weakly at first. I adjusted the system volume all the way up and it is now understandable. The audio is set up in the left sterio field.
I also tried to insert the Garmin 430; however, I was unsuccessful in powering it up. I don't think it is engaging into the pins correcty. I will have to work on this later.
