Brief Description: Access for the Wing Attach and End Layup
03/10/2008 I cut the UND for the forward face layup. 03/13/2008 I layed up the UND at alternating 45° in 2 layers. I peel ply'd the center most section 03/16/2008 I cleaned up the forward holes and cut the outboard wing bolt access port. 03/18/2008 I layed up the end caps with a 45° BID. I used flox to reinforce the corners. I also used dry micro in the wing bolt access holes to protect the foam.
