Michael's Cozy Web Site
Date:  4-7-2007
Number of Hours:  14.00
Manual Reference:  Step 1
Brief Description:  Trimming the Foam Blocks and Cutting the Cores
04/07/2007 I made the templates for the canard cores. I copied the templates and glued them to formica. After cutting them out, I checked to the originals and trimmed the A&B templates together.
04/14/2007 I cut out the three main canard cores and the end tip cores. I cut the center spar section. Still need to cut the outer spar sections.
04/15/2007 I trimmed off the outer wing tip core. I cut out the spar cap cutouts on all three cores.
04/21/2007 I trimmed off the leading edges to expose the section to be glass on the shear web.
Making the Canard SparTemplates
Trial Block
Trial Block
Using Hotwire on Trial Block
