Brief Description: Carving the Foam - Shoulder Brace and Headrest
08/13/2006 I started to cut out the foam for the headrests. I cut out the sides for the right headrest and marked up the front and rear of the right and front of the left, but did not cut them out yet. 08/14/2006 I finished cutting out the head rest foam and the foam for the shoulder support. I still need to trim the foam to fit the fuselage and each other 08/20/2006 I cut ot the hardpoints for the shoulder strap attach points. I used 5 min epoxy to put them in the shoulder support.
