Drilled the seatbelt anchors. For some reason the holes are coming out a little undersized. I checked with a set of calipers and the bit is .188, the bolt is .185 and when I drill the hole, the bolt won't go through. I also discovered that the holes I drilledin F705A are a little oblong. I'm not sure if I should replace the part or not. Asked the forum folks so we'll see what they say.
