Set aside the firewall to get some more pieces ready for priming. Started working on the main spar passthrough center section (F704 series) but didn't get too far until I realized I didn't have the close tolerance bolts. This is probably because I'm building out of order and these bolts probably come with the wing kit hardware. So I moved on to the next set of bulkeheads (705 series). I drew a centerline on the aluminum bar that reinforces wehre the seatbelts attach. Not really much done tonight.
PRETTY! But I can't build it without the bolts.
All the parts for the seat bulkhead
Drew a centeriline to make sure the holes are straight for the doubler
