I got almost no work done this week because of an exercise at work. Just got crushed with long hours and a lot to do. I think I've said already, but this project has a funny way of making the simple complicated and the complicated simple. When you look at the F704 spar, it looks like it's already done and all you have to do is drill a couple parts and rivet them on then move on to the next part. Well it isn't anything like that and I've been working on this part for days...18 nutplates, plus another 10 on some items that attach to the front spar, then pondering wiring runs that will need holes drilled and figuring out what should be done now versus later has confounded me a little more than it should have. I've been saying for three weeks now that I"ll be bending the longerons and assembling the rear fuselage cone...I said it again this week and I'm still here working on everything but the longerons. Having a blast, but it is definitely a slow process right now.
Drilling for nutplates. cleco, drive the screw a ways, remove a cleco and drill then countersink
These are the nutplates that are used through most of the airplane KS1000-08
