GREGORY'S WEB SITE
Date:  3-21-2019
Number of Hours:  1.00
Brief Description:  Seatbelt anchors
Drilled the seatbelt anchors. For some reason the holes are coming out a little undersized. I checked with a set of calipers and the bit is .188, the bolt is .185 and when I drill the hole, the bolt won't go through.
I also discovered that the holes I drilledin F705A are a little oblong. I'm not sure if I should replace the part or not. Asked the forum folks so we'll see what they say.
Clamping to drill the anchors to the bulkhead
The anchors all drilled
Oblong holes.  Not sure if I can pass this or not
