GREGORY'S WEB SITE
Date:  3-5-2019
Number of Hours:  0.50
Brief Description:  Bulkheads
Might have had an oops today. I think I cut the F-705B bar where the seatbelts attach. I measured the scale drawings to determine the overhang but didn't double-check the overall length before I cut it. Came out about 1/4" shorter than the plans call for. Emailed Vans to see if that was going to be a problem...probably is. I've already looked and even in England, aluminum bar is pretty cheap so not an expensive fix or anything that's going to hold me up long.
To make myself feel better I clecoed all the other spars together so I would have something to show for the day other than a mistake.
Also got an email from Vans saying I don't need the close-tolerance bolts to drill the spar. I'll go to the fastner store in Mildenhall and get some bolts that will fit.
