GA Aerospace’s Web Site
Date:  7-10-2020
Number of Hours:  5.00
Brief Description:  N-16-12-14 Compliance
07/10/20 5 hours
The AOA was installed.
The left wing was placed upside-down.
The VA-195H was removed from the left wing.
An SD-42-BSLF rivet, was riveted onto the left wing, A hole was already prepunched.
A hole was drilled into the J channel on the top of the wing and a tie-wrap was installed.
The 1/8 plastic tubing was routed from the rivet to the root of the wing through the J channel.
Although we did trim the drill templates, we noticed the guide hole was already were we needed it, we just need to expand the hole, but for that we need a 15/32" drill bit.
A plastic tubing adapater was created from PT-035X1/4 and the inboard end of the 1/8 tubing was inserted into it and sealed with RTV.
A copy of this Notification has been added to the maintenance manual.
