46iS-11 1: The magnetic plug was safety-wired to the crankshaft plug screw. 2: The oil pressure regulator plug was safety-wired to the engine pump housing. To do so, the radiator had to be semi-removed. 3: The oil tank drain plug had already been previously safety-wired.
